Well it wasn’t the fuel filters….(to make a short story long)
Wow Rich - what a great read and thank you for the education. See what happens when you’re stuck in a motel longer than you want to be……. 😎
Dang!!!! I can't wait to hear the rest of the story!
I don’t know it yet but I should later today. When I’m ready to write about it is another story. But we’ll see.
This is why I hate having to rely on “experts”! A truck repair outfit working on what is a very common engine configuration should have the competence to get a diagnosis right the first time. I would be more forgiving if you were asking them to diagnose and repair your Lamborghini which they most certainly would know nothing about!
I hope they will work out a fair and equitable deal for you especially if it cost you several days unnecessarily.
Well they got it all back together and cut the labor down to what was necessary, and I’m headed east, so far so good. I have an appointment at the Freightliner shop in Lincoln this morning to have them check the intake and exhaust systems, try to answer some unanswered questions, and also check all the work the other shop did. Its worth a couple more hours of shop time at this point to try to regain my confidence in this rig.
. . . . . I hope they will work out a fair and equitable deal for you especially if it cost you several days unnecessarily.
My definition of "equitable" might differ from others. My intent would be to pay only for what parts and labor would be required for the repair to be done correctly from the get go minus the extra time & trouble I incurred due to someone else learning and not knowing. The $$ they didn't receive from me for work that shouldn't have been done & for the time & trouble that waste generated for me would be an incurred expense their accountant could put under the heading "training" as at face value, they were clearly in need of more.
I certainly understand the regaining of the confidence factor. I hope it all checks out at your next stop.
Here it is just about exactly as I suspected - glad I took it to another shop. I’ll reserve my opinion(s) - just glad it will be buttoned up right.
JOB #1 EA
COMPLAINT
CAUSE CORRECTION
EXPRESS ASSESSMENT
CUSTOMER STATES THEY HAD UNIT AT FLOYD'S - THEY REPLACED EXH MANIFOLD BUT STILL HAS A LEAK NEAR THE INTAKE.
1851 40051 CHECKED CODES AND THERE WERE NO CODES PRESENT. MONITORED SENSORS WITH KEY ON ENGINE OFF AND THEY WERE READING IN SPEC. VISUALLY INSPECTED FOR INTAKE LEAKS AND FOUND THE AIR COMPRESSOR INLET PIPE WAS NOT HOOKED UP TO THE AIR COMPRESSOR CAUSING A LARGE BOOST LEAK. WILL NEED TO REPLACE 90 DEGREE AIR COMPRESSOR INLET HOSE AND CLAMPS AND THEN SECURE THE COMPRESSOR INLET PIPE WITH P CLAMPS AT THE COMPRESSOR AND ENGINE. CURRENTLY THE PIPE IS NOT SECURED. CHECKED OVER FROM PREVIOUS REPAIRS AND FOUND AN EXHAUST LEAK AT THE TURBO OUTLET FLANGE RIGHT AT THE OUTLET OF THE TURBO, THE TURBO INLET CLAMP NEEDS REPOSITIONED, THERES A LOOSE CLAMP AT THE AIR FILTER INLET, THERES A LOOSE BOLT AT THE LEFT HAND RADIATOR SUPPORT AND THE LOWER RADIATOR HOSE IS RUBBING ON THE FRAME AND WILL NEED REPOSITIONED.
Interesting reading to say the least….
JOB #3 100
COMPLAINT
CAUSE CORRECTION
SERVICE ORDER: RA108024866 ESTIMATE: ES108020897
DESCRIPTION
EST PER EA - REPLACE AIR COMPRESSOR HOSE/CLAMPS AND TURBO OUTLET FLANGE CLAMP/GASKETS - SECURE INLET PIPE, REPOSITION CLAMP AT TURBO INLET AND HOSE AT LOWER RADIATOR - TIGHTEN CLAMP AT AIR FILTER INLET AND BOLT AT LH RADIATOR SUPPORT REPLACE AIR COMPRESSOR HOSE/CLAMPS AND TURBO OUTLET FLANGE CLAMP/GASKETS - SECURE INLET PIPE, REPOSITION CLAMP AT TURBO INLET AND HOSE AT LOWER RADIATOR - TIGHTEN CLAMP AT AIR FILTER INLET AND BOLT AT LH RADIATOR SUPPORT 1,110.00
108D/DDE A4722005052
LINE COOLANT SUPPLY ONE CYL AI 22.65
108D/TCX AMS012
GASKET-4 INCH SPHERICAL W/TABS 17.14
108D/TCX T130130349AC2
CLAMP-V BAND 4 HDEP SPHERICAL 24.67
***EST SHOP SUPPLIES*** 166.50
16.75
Parts: $64.46 Labor: $1,110.00
Misc: $166.50
$1,340.96
Plus of course $370 for the initial assessment and a few bucks for supplies and tax. But what’s another $1,800 at this point….Any yes, I will be talking to the management at Floyds. Might not get me anywhere, but I will certainly have the conversation.
Floyds would be owing me some money or at least a fantastic explanation as to why they don't.
There is a form someplace on the FCC website to report dealer experiences and from what I understand, FTL takes these reports seriously.
