AC low on Freon
bro61021
Palm Coast Florida
Keystone
Springdale
33FT
None
None
My AC unit still cools but stuggles when in the direct sun above 90 degrees. It runs continuously. We had the unit seviced but no change. The tech said we are low on freon and would need to replace the roof unit as you cant add freon to RV AC's. Is there a way to splice the lines and add a valve to add freon.
How does he know it's low on freon? Meantime, if you're trying to cool a 33' travel trailer with one rooftop ac in direct sun @ 90+° it's not likely going to shut down.
Usually when they leak Freon, the inside coils (evaporator) will ice up.
Perhaps the fan and/or ducts need cleaning.
My 2017 34 ft Class A would keep the interior at 74 degrees in Florida, in July, in full sun, with one 15k BTU a/c.
It’s not ideal, but one should work fine.
Rule of thumb on a working ac unit is the temp coming out of the AC vent typically is usually no cooler than 2 degrees below the outside temperature.
Well, that statement is absolutely false.
Yeah, that's hard to believe when the inside temp is 10 or more degrees cooler than the outside, how could that be?
Nobody answered the original question. Yes it’s possible. But the suggestion is the saddle ports that are added after the fact usually leak worse after a bit so you are just postponing the ac replacement.
There are more efficient replacement ACs that might be better. They seem to be about the same price as the older ones.
That's because it's not the case. The air coming from the vents is going to be 25+° cooler than the outside ambient temperature on a hot summer day. The vent closest to my unit is blowing 68°.
Did your tech give the temp of the air coming from the vents? If not check it yourself, if it's in the neighborhood of 65-70° it's not your unit, it's doing its job.
How did the a/c tech check the freon level since there are no ports on these rv systems. That is why freop can not be added.
