2023-2024 Equinox -updated flat tow instructions
Miker163
Michigan
Coachman
Pursuit 29SS
Ford F53
7.3L. V8
2023 Equinox AWD
This morning, GM issued an update to dealers revising flat yow instructions. Notification to vehicle owners is pending.
Reference Number: GCUS-9-15364
Dinghy Towing information is incorrect in Owner’s Manual 2023 – 2024 – Chevrolet Equinox (non-EV)​
GM CUSTOMER CARE & AFTERSALES
URGENT - DISTRIBUTE IMMEDIATELY
DATE
11-16-2023
SUBJECT
MODELS
TO
All Chevrolet Dealers
ATTN
Service Manager, Service Advisor, Service Technician, Customer Relations Manager, General Sales Manager, Sales Management,
All,
The printing of the Owner’s Manual for the 2023 and 2024 Chevrolet Equinox contains an error in the Dinghy Towing instructions.
The incorrect instructions say to leave the car powered on in accessory mode and the battery connected, which is what the 2018-2022 model years require. Leaving the battery connected and in accessory mode can cause tire squeal and steering wheel shake while being dinghy towed on long, cloverleaf type entrance/exit ramps.
The directions should have been updated because of the change in the braking system.
The new instructions are:
To dinghy tow:
1. Position the front of the vehicle being towed—with all four wheels on the ground—behind the towing vehicle.
2. Secure it to the towing vehicle.
3. Put the vehicle in N (Neutral).
4. Shut engine off (vehicle will remain in accessory mode).
5. Release the Electric Parking Brake (EPB), if applied.
6. Disconnect the negative (-) terminal connector from the 12-volt battery.
7. Close the hood of the vehicle.
Once the destination is reached:
  1. Shift the vehicle to P (Park).
  1. Reconnect the negative (-) terminal connector to the 12-volt battery.
  1. Start the engine and let it idle for more than three minutes before driving the vehicle.
Caution
For AWD vehicles only, a lubrication cycle is recommended after 2700 km (1,700 miles) of recreational dinghy towing. Drive the vehicle in AWD up to 40 km/h (25 mph) for a minimum of 30 seconds to distribute lubrication throughout the rear drive module and protect the system for additional dinghy towing.
Updated owner’s manual pages were being included at the vehicle assembly plants in early November. However, the updated pages erroneously excluded the all-wheel drive (AWD) from being dinghy towed. The pages will be updated again, but some vehicles will reach dealers with the incorrect information.
A mailout will go to customers who have purchased a 2023 or 2024 Equinox, and to dealers who have inventory of cars that do not have the correctly updated pages, once the revision is available.
If customers ask for clarification due to the discrepancies, please share that both the FWD and AWD versions are able to be dinghy towed, following the newly revised procedure.
Thank you for your cooperation.
END OF MESSAGE GM CUSTOMER CARE & AFTERSALES
Document : VSP Logon Form
This message link is only valid through the expiry date.
Expires:Feb 16, 2024 00:00 ET
mail
mail
Nothing in this message is intended to constitute an electronic signature unless a specific statement to the contrary is included in this message. Confidentiality Note: This message is intended only for the person or entity to which it is addressed. It may contain General Motors confidential and/or privileged material. Any review, transmission, dissemination or other use, or taking of any action in reliance upon this message by persons or entities other than the intended recipient is prohibited and may be unlawful. If you received this message in error, please contact the sender and delete it from your computer.
DATE
11-16-2023
SUBJECT
MODELS
TO
ATTN
All,
To dinghy tow:
Caution
mail
mail
  • GM-update-111723.pdf
