Question Can I replace the range on my RV?
Mikechen
LA
FORD
COACHMAN
F450
Can I replace this style range on my RV? The old range has too little power. I want to replace it with one with stronger power.
Welcome to the group. I can not advise on the upgrade you to do. Can you give more information on the new equipment.
RV stove tops come in a few sizes probably get the dimensions and then see if you can find a higher output range that will fit. You could also experiment with larger burners. Contact manufacturer and see if there is anything available.
Not sure what you mean by more power? If the burners are not putting out enough heat, look at the regulators in the system. One is in the stove top and one is your main regulator. We see many bad regulators. Suburban recommends turning the main regulator up to at least 12 inches of water column. Most put out about 11 from the factory. I have seen where guys have said they were advised to go as high as 14.......
