Test drove a 32pbs and found the front air suspension unacceptably stiff. Has anyone remedied this?
Also the cruise control didn't work and after a few miles the abs light came on. Is there a fix?
Thanks
Frank
What year is this? does it have air brakes? Random ABS lights are not uncommon and might clear with a few ignition cycles. If not a code reader is in order - ABS systems generate fault codes. The cruise may or may not cause a fault code so a physical inspection of the system will probably be needed.
