Allegro brake fluid reservoir?
The two sets of dualies on the rear axle each have a thin metal tube that meet in a chassis beam and I lose clear view from there.
The two wheels on the front axle each have a flexible hose (not the same thin metal tubes) that join up at a chassis beam, and again I lose clear view from that point.
However, I speculate that perhaps this may be the master cylinder. Photos attached. Does that look accurate?
It is located closest to the front wheel on the driver's side and it has a reservoir. I've been unable to precisely confirm that its thicker hoses in fact connect to the wheel hoses/tubes, so I'm speculating.
That is it
Cracking that sucker open was tough.
An even bigger challenge was snapping it back shut.
(Note for posterity: use something metal as leverage to dislodge the clamps and re-place them. A flat screwdriver should work very well, but as I did't have one I clumsily fumbled around with a hammer claw instead until luck fell my way.)
now, the $10,000 question is,,,where is that fluid going. This is a diesel. I am assuming that, like Rich said, your brake system has a hydraulic brake booster. The good of that is your leak cannot be being sucked away in a vacuum booster. Start looking at the bottom inside of all wheels. That fluid has to start showing up.
