silversurfer.spence@gmail
- Jun 26, 2021
thx for the info. if I change the bubble on the door I won't be sure it is correct. Liked your idea of the bullseye bubble - my next purchase. thxI have bubbles on front and side of fridge, but when they are level the coach seems to lean forward. A marble will roll from back to front when "leveled". Is there another (manual) way to level the coach? Things work ok as is, but wanted to check.
Got it thx. Great forum. Do u happen to know where the fuse is for the lighter? All the ones under the dash are ok. 2001 winni adventurer. We use it for our phone jacks.Thx
My iPhone has a feature or app called MEASURE. There is the 2nd item as part of this which is LEVEL. I just switch it on and lay it on the floor about midway front to back and midway left to right. If you want your countertops level, then put the level there.Could you adjust the front-to-back bubble level on your fridge? Otherwise, get a round “bullseye” level like one of these.
Lay it on the floor to check your level when making adjustments.
